I'm going to junk yard in morning to grab an iac valve then swap it in and see if it changes, then I'll mess with the screw.
It is part of the throttle body where the coolant goes through,i think yours is built in to the throttle body i am not really sure.If changing the iac doesnt help i would see if i can find a used throttle body,the fiav allows the coolant to go through and warm up the car then it shuts after a certain amount of time.
what is your idle at now on a cold start and a warm start now that you adjusted the idle screw
Ok cold morning start and no fast idle? It was a hard start and around 600rpm till it warmed up. This is why I didn't want to mess with the screw, I'm not stupid I knee it was something else. Damn!
Dont panic is ok. I told u u need to let it idle for 14 min no driving. My friend has a iac motor i could get it for u. Pm me. Coolant on the iac has to do anything with the idle. Mine right now is bypass for the summer. The pcm has the settings for engine warm up. When cold engine rev around 1500 to 2000 rpm to get to operating temp and it should to down to 700 to 800 rpm. If you dont get that jump to 2000 when cold the iac is bad.
Yeah the iac deffinantly seems to be bad,just give it a day or two for the computer to adjust and if it is still not getting a high idle the iac is bad like i said it was.
