[IMG]<a href="http://s1238.photobucket.com/albums/ff488/gvp1632/?action=view&current=FILE0008.jpg" target="_blank"><img src="http://i1238.photobucket.com/albums/ff488/gvp1632/FILE0008.jpg" border="0" alt="Photobucket"></a>[/IMG]
what would i use to hide the wires
just cut some plastic and fit it in there to cover the wires
You should be able to find a dash install kit for a 1/2 din equalizer.
I've been looking to find a pocket to put in there so I can throw stuff in there.
02 Galant GTZ stock
00 S10 Bagged on 20's Suicide Doors 5 link and control arms, more to come!
i went into google and typed in "half din pocket install" and this was the first result:
http://www.amazon.com/Metra-Universa.../dp/B00032AZT6
black painted carton may work
__________________
If that's just layin there, it won't be secure causing wires to come loose and give you problems. Get the above mention kit, so it's mounted, secure and with no gaps. You may have to modify with a Dremel if one is not available... razor blade with a steady and careful hand.
You can also try....
http://www.parts-express.com/pe/show...ource=googleps
I have created wonders with this stuff.
Before
After
This is is not for everyone,some may think it's cluttered, but every button has it's purpose
I kinda like it. Nice....
The key to Immortality is first living a life worth remembering.
