rear disk coversion? lol
okay so i noticed a clunking noise, thinking it was the drum bake i took my wheel off, sure enough it was the drum brake and it had been loosened, so i put it back in place, made sure it was secure, and put the wheel back on, the noise then went away, but after i hit some lightly bumpy road, it came back, and i took the wheel off, and it was loosened AGAIN, my question is how to fix it so it wont loosen again, thanks!
i didn't even know that was possible haha, i've been looking it up, about how much does it cost to convert it i'm definitely interested, i freakin hate disc brakes
What exactly loosened? Not normal to do that unless you have some worn or missing hardware.
The problem is the drum brake...LOL.
Rear Disc FTW.
U need a new one asap or new rear breaks..... And a conversion is easy seeing we already have break lines back there just got find u a 2nd gem eclipse and take everything from them.... Ur set lol
I spoon feed only once, here ya go! :)
https://www.thegalantcenter.org/show...ight=rear+disk
2002 ES i4 SOHC Mitsubishi Galant
