usually all the clutches are the same disc and plate wise but the AWD and FWD flywheels are different. like i have a 2100 that was from a GSX but with a FWD flywheel.
clutch issue: in my research i found that the Exedy Clutches are OEM mitsu clutch...... for my car 92 GS, the GGSX and The Eclipse GSX, Exedy lists it as part 05071....
Clutch for the vr4 lists as 5048 as well as for the 7g, 8g, 1g and 2g etc clutches
Beck Arnley lists part number 061-9027 as the clutch for my car as well as the vr4, 7g, and 8g, 1g, 2g etc
both are 225mm 20T 7/8
are the pressure plates different?
Caps lists the clutches as different for every car anyway
so im kinda confused on which clutch i need to get, i read on Gvr4 that the vr4 clutch doesnt work in the fwd because the flywheel isnt stepped, but i looked at mine and it is stepped....kinda lost
2014 Lancer Evo GSR
1996 Galant S 5 Speed Turbo
