Just go with r1concepts rotors. They are very good quality. I'm running my evo brembos setup with their slotted rotors with no problems.
For your stock single piston calipers you dont need brembo brand rotors.
So I need to change my warped front brakes. I4 2000 Galant.
I am looking for straight out replacement parts that don't need modifications for installation.
Brembo brand.
Just the front rotors.
Your most economical starting set that is slotted and/or drilled.
A specific Brembo part number would be great so I can try to dig a good price on the internet.
Thanks.
I was reading other related posts on this issue, before I posted this question. What I am trying to achieve is to install a good quality pair of front rotors and not have to replace low end ones again over.
I have never used r1concepts so I can't say anything about them, apart from what I read. What have read is conflicting but generally said to last 30k....
Any thoughts?
Id go with R1 concpets, they are a quality rotor, I drive my car hard and never had an issue with scoring, pitting or scratching. I ferquelty do mountain runs downhill and have not had a problem
this is for the 6a13tt legnums/galants. I am not sure what your cars are like bit this should help soemwhat.
The Front List•Evo (5/6/7/8/9) Brembo Calipers (front)
•Evo (5/6/7/8/9) caliper bolts - 4 x M12 bolts (as Brembo calipers have different thread pattern to VR4 calipers)
•Evo (5/6/7/8/9) Springs + clips
•Evo (5/6/7/8/9) brake squeal shims
•Evo (5/6/7/8/9) brake disks (front) 320mm
•Evo (5/6/7/8/9) brake pads (front) 131 x 75 x 15mm
•Brake lines - standard VR4 will suffice so I dont need any
The Rear List•Evo (5/6/7/8/9) Brembo Calipers (rear)
•Evo (5/6/7/8/9) Brembo calipers bolts (rear) + washers
•Evo (5/6/7/8/9) brake disks (rear) 300mm
•Evo (5/6/7/8/9) brake pads (rear) 76 x 65 x 14mm
•Brake lines - evo7+ lines or modified/custom lines
original thread on cvr4 forums for more details on the discussion.
http://www.clubvr4.com/forum/showthr...ghlight=brembo
