Thread: How to Install front motor mount the RIGHT way
Showing results 1 to 15 of 15
    11-29-2009
    Chadds Ford, PA
    2,768
    Alright this how to is basically How to install your front motor mount 100% right. This can also be done with the stock mount but I am not sure if it will have adverse effects.
    But basically here is the stock bolt I don’t know the diameter of it but it’s small.
    Now here is the same stock front mount bolt through the stock mount
    Notice how there is a lot of wiggle room, so once you shift the whole assembly is going to shift forward when you are really banging through the gears.
    What you can do is get a bigger bolt for the front mount
    Here is said bigger bolt
    This was the biggest bolt Lowes had at 5/8 inch in diameter, the stock mount’s hole is ¾ so there is still a little wiggle room but I am not about to go out and order a perfect fitting bolt.
    Now here below we see the stock bolt in the poly mount
    The poly mount metal insert is the SAME as the stock one that’s why it seems as if Prothane messed up in their design. But it’s actually Mitsu who dropped the ball on their design. SO if you use the stock bolt on the poly mounts you are stick going to have the engine rock.
    Now here below is my 5/8 bolt in the poly mount. Since both the stock and poly metal sleeve are the same you can also do this with the stock mount.
    See how little wiggle room there is now?
    I don’t have picts for the rest but it’s quite explanatory if you can get the stock mount off you can do this.
    1. Remove the stock mount and subframe if you choose to do so, I had to as all of my stuff is seized on by rust
    2. Now break out your drill (this is assuming you have bought the bigger bolt) Get the drill bit according to the size of your new bigger bolt.
    3. Start drilling on the black bracket that attaches to the Trans, you want to just drill the stock holes out bigger.
    4. Once both holes are drilled out to size make sure you go and de-burr the holes so the mount doesn’t get snagged on it upon reinstall.
    5. Reinstall that shit
    Now these next steps are very important
    6. Go do a victory dance
    7. Drink a soda(I am under 21)
    8. Take a nap
    9. Torque everything down
    10. Startup car let it idle for a bit.
    11. Shut off and check for torque on motor mount bolt.
    12. Drive your car like a BAWS
    04-29-2009
    Holyoke,Massachusettes
    3,600
    Never had that with mine
    FreakyDeaky
    2kG 6g72/74 5 speed
    05-14-2010
    Coachella, CA
    5,954
    Never noticed the amount of gap. LOL.
    11-29-2009
    Chadds Ford, PA
    2,768
    Quote Originally Posted by Corey2kG View Post
    Did you just not notice it? Cause the I4 and the V6 bolt and motor mount are both the same part numbers
    04-29-2009
    3,600
    But wouldnt that mean alot of play??? Plus Ive changed that mount SEVERAL times lol
    FreakyDeaky
    2kG 6g72/74 5 speed
    Here's a good pic of the cause and effect of the stock design
    Good info
    Me I'm a lil of both
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    moved to tutorials
    Build Thread
    11-29-2009
    Chadds Ford, PA
    2,768
    Yeah there is alot of play
    11-29-2009
    Chadds Ford, PA
    2,768
    moved to tutorials
    thank-you
    08-04-2003
    NY
    4,344
    I dont remember having that much play in mine either. Are you sure you didnt put the wrong bolt in there?
    99' Galant ES
    4G64/63T
    AEM EMS
    11-29-2009
    Chadds Ford, PA
    2,768
    Quote Originally Posted by Stewi View Post
    Yeah positive, I am not the only one who noticed it. A few others on club3g and GT both noticed and did the same mod.
    Surely though, while there is a lot of play with the bolt in the inner sleeve, when the bolt is tightened, the bracket is squeezed together onto the inner sleeve of the rubber mount so therefore locking it into place. If the sleeve was moving on it's edges inside the bracket it would squeek and rattle and you would see the wear marks inside the bracket flanges.
    Yeah i noticed that too but i convinced myself that mitsubishi knows what they are doing and used that size bolt for a reason.. maybe i was wrong..
    11-29-2009
    Chadds Ford, PA
    2,768
    Quote Originally Posted by The Vee View Post
    ON a stock motor yes. But anything upgraded is going to torque more causing movement especially on the big v6 swaps and the turbo 4's
  15. #15
    05-03-2007
    Socal/Central Coast
    3,803
    It can't be the wrong bolt, because the bolt fits perfectly into the hole on the metal bracket (which is why we need to drill it out).
    Kinda old topic but I figured I would bump it since it has been coming up again recently.
