U really news to make a thread for all ur questions, did u try searching, I now there's a skicky about suspension..
HTC EVO 4G
So another ? So I'm looking to get a front strut bar. Not sure what the real name is but you guys know what I mean. I'm curious which one I should get for my 95 Galant S. I've heard about different moving parts arnt nessasarily good. So just curious on your guys recommendations and where to get them thanks
HTC EVO 4G
MODS
5 speed swap
Eibach Pro Kit on GR2 Struts
Cold Air Intake
Outlander Intake Manifold
6G72 V6 Throttle Body
6G72 V6 Fuel Pump
Axle Back Exhaust (ebay)
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
Prothane Motor Mount Inserts
Mitsubishi OEM Strut Bar
http://www.ebay.com/itm/90-NEW-Mitsu...43243919143513
Upper strut tower brace or bar. Any of them for a 2g eclipse will work. If your not gunna buy the vr4 one just buy a cheaper eBay one. They all do the same thing but the vr4 one is a beast. I with I had the vr4 stb but I don't. :( mine is a cheap one off eBay it's called DNA.
From a couple of days ago.
Im not saying dont ask, just put some effort and search on TGC or the web for answers, and if dont come up with anything then post a legit question. If you just went to Ebay and typed "95 Galant upper strut bar" and got 94-98 galant strut bar in the results then it most likely will fit a 95 Galant.
Im not trying to rant on you, but these are questions that are chewed over and over again too many times and members get frustrated because they have to spoon-feed you answers that you can find by yourself with a bit of effort.
Your question about the smoke coming out on a cold start up was pretty legit and you got a straight answer from me - valve seals. Been there done that. I gave you an answer cuz I had the same thing happening to me and I was wondering too. I did the compression test - it checked out, i inspected my turbo for leaks - it checked out, but it still smoked and it stopped after it warmed up. When I got on it it would still smoke.....so yes you have bad valve seals. The thread about the compression causing smoking was very unnecessary.
I apologize that i hi-jacked your thread, but some things had to be said and made clear.
Kool kool i gotcha thIs thread was ment to be more of a poll and opinions thread. Like who has what strut bar and any opinions on the best one.
