Thread: projector headlight alignment
Page 3 of 3 FirstFirst 123
Showing results 41 to 44 of 44
  1. #41
    05-14-2010
    Coachella, CA
    5,954
    It will be with the JM projectors. If I ever do the oem's it would be some big ass D2S OEM projectors for sure.
  2. #42
    Quote Originally Posted by carl3g View Post
    Its teal simple with the oem heads. Bake heads until you can pry apart the housing, unscrew that silver thing that sits infront of the bulb. From the front, you slide in the mh1 and use the proper hardware provided to lock it in place. Seal her back up and your good to go.
    I've done the md2s retro for my 3g. Looms intimidating but its not.
    yeh, i seen a video of a guy install on youtube ...pretty straight forward with h1s but i kinda like the look of the aftermarket ones..i just need to kno if the h1s will fit in those and im good to go
  3. #43
    i would like also a pair..:)
  4. #44
    05-14-2010
    Coachella, CA
    5,954
    Seriously thinking about pulling the trigger in the Mini H1's!! As in right now....
    Maybe if I could sell off the eclipse sonars I have to suppress the cost a bit.
