remote starter help
im in a little jam. i installed a bulldog security remote starter in my car and it SORTA works. i need one more wire to connect. and that is to get the remote starter into tach mode. It says to connect the wire to the negative side of the coil or the tach wire at the coil pack under the hood. can someone clarify this for me. where exactly is the negative side of the coil. Thanks
