Many tuners built turbo, then calculated power and etc. However, this is not the right approach. Correctly first, calculate, and then to build the engine. There are a few simple points.
1) Initial settings. (what we have before construction)
2) the Desired result (the one that we want to get)
3) Calculation (we consider the air, fuel, power etc.)
4) Selection of the components (turbine, parts, etc.)
5) Installation (actually Assembly)
6) setup (ECU, pressure, fuel, etc.)
That's it for this scheme will work.
