Thread: 18 x 8.5 frnt/ 18 x 9.5
Showing results 1 to 6 of 6
    Hey my professional Galant owners is this wheel combo(18 x 8.5 front/ 18 x 9.5 rear) safe for the 9G or is it a bit much?
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    You can make them work, If you want a definitive answer post the offset of the wheels your looking at ;)
    4g64T 5spd
    Size: 18x8.5 front 18x9.5 rear
    bolt pattern: 5x114.3 / 5x4.5
    offset: +32 front +25 rear
    i have xxr 522's 18x8.5 +30 all around my 9g lowered on WORKS springs. fronts fit fine. rears needed major fender roll. was rubbing pretty bad with 8.5's so 9.5's would require fender roll unless you arent lowered
    9g Baby!
    My 18x8.5 needed a roll for the back, but I was dropped on ebaich prokit
    04 GTS 9G
    FoR Sale:
    2004-2006 Fog Lights $50
    shoot me a pm
    18X9 30offset and 18x9.5 35offset +10mm offset
    Front dropped around 2inches(need more low)
    Rear dropped around 3ish inches
    245/40 tires around, no rubing but i had to roll my fenders
