OK, I'm an idiot!!!! I just saw a video on youtube and I was trying to go over the lower control arm when I should have been feeding it up from the bottom through the lower control arm. DUH!!!
One of my rear shocks broke. Yes, the inner rod snapped at the upper mount just below the nut. I was able to get it all apart and install the new shock into the spring but now I cannot get it onto the car, it is too long to go into the lower mount or even over the lower control arm. I tried pushing down on the hub but not even close. I have looked in three manuals including the mitsu and none say tha tthe spring needs compressed to install on the car? Does anyone know if I must compress the spring or maybe just disconnect the upper link to get the hub to fall low enough?!?!?
2002 ES, V6, 140K
2002 ES, V6, 140K
lol
MODS
5 speed swap
Eibach Pro Kit on GR2 Struts
Cold Air Intake
Outlander Intake Manifold
6G72 V6 Throttle Body
6G72 V6 Fuel Pump
Axle Back Exhaust (ebay)
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
Prothane Motor Mount Inserts
