Most likely they will be the same part numbers. For example the battery looks like a group 86 which the galants take them already.
4g64T 5spd
Not mine. But not telling who it is for.
Sent from my Galaxy S4
'91 Kawasaki ZX7 (SOLD)
'95 Kawasaki ZX9R
^^Looks damn good!
-Greg
^^Nice COP setup!
-Greg
Yeah that COP does look top notch Omega and so does the valve cover spdracr
Old coilovers were rusted and seized.
Took them apart, took me 3 hours with pb blaster, chisel, hammer and a torch. The lock rings got chewed up but they're still functional. Stripped all the springs and front sleeves and coated them. And used a wire wheel on a bench grinder to get all the baked rust off the threads. Used plenty of anti seize.
Those are going on the daily soon.
'95 Kawasaki ZX9R
Anti-seize is man's best friend lol!
-Greg
you got that right, greg! took the words right out of my mouth.
My babies
Put new spark plugs in the Galant, I have the infamous p0300, I think mine is my 02 sensors still, will order new ones, I only have 2 bungs with my exhaust so I spliced the left bank together and the right bank together, this time I'm going to try to splice both uppers together and bother lowers together, I'll see if that helps.
I also undid the wire loom and tucked the MDP wires since the 6g74 IM makes the stock wires stretch across the 74 IM.
01 Galant ES V6 MT (sold)
00 Eclipse RS MT
Hey Spdrcr....I also have megans coilovers and will be installing them within this month....I plan to go as low as I can go to eliminate the wheel gap I dont want them to tuck does any one know the camber plate should be centered?
wise up or stand down
'95 Kawasaki ZX9R
Is that the cat warm-up code? I forgot the number but i think thats the code I had. I still have a light on now but just been riding with it. I'll have to get it scanned again at somepoint and figure a solution. Same shop told me recently, seems like my headgasket is tryna give out on me, but to let it go for the moment. Was leaking a small amount of oil, and they also said coolant. But all I ever see in the driveway is oil, but none lately for the past 3 days
P0300 could be 1 of several things, I got my 2 new 02 sensors today, I work until sunday night so monday I'll extend and put in the 02 sensors and hopefully the P0300 code goes away, I'll let you know if it fixes it.
00 Eclipse RS MT
P0300 is a random misfire which in his case is probably caused by a rich condition.
Sent from my iPhone 5 using Tapatalk Pro.
My p0300 was caused by a coil and bad ground straps.
There really isn't one definite fix for it. It's such a vague code that has lots of different ways to fix it.
'95 Kawasaki ZX9R
