Originally Posted by
6G72gearhead
The second add does not specify bolt pattern, so make sure it's 5x114.3 which is the same as 5x4.5" as 17x7"s or 17x8"s they will fit fine, if the offset is +35on a 17x8" I have fit 245/40/17s all the way around, for a 17x7 the max I would do is a 235. It depends also on how low you are as to any issues with fender clearance, if you want it to handle the wider the better at this point. If you want to go low a narrower tire will yield more clearance, however you can protect the wheels lip with the sidewall of the tire a little. This is nice if you have to park along taller curbs.
