turbo bulid
ok so every says go 5 speed on turbo, but there are peolpe who run turbo on bult trans...... when you say bult trans, what has to be change to run 8psi.... some say a torque convertor and trans oil cooler should work well.... is there anything else to be change or add to prolong and support the life of my auto tranny on 8psi...
i did my cousins at 7psi and drove the car for like 2yrs before I made it 5spd (Goin for more power). with stock auto made 230hp hold strong. and I drove tht in manual switch mode. never slip or acted up. yes I will recommend to change fluid and put good fluid (dealer if u have funds) and install a trans cooler.
