Nice! OZ F1 Rally wheels ftw!
Done! Need different lug nuts and replacement center caps
Thanks! Oem lugs wont work well. I actually bought extended close ended lugs from a truck from the shop I got my tires from. They also have the washer on the ends. I can probably take a pic later if you want.
Temporary tie bar (Not very sturdy) and I'm missing a socket lol
Found an automatic GS with a Dohc 64. I wasn't expecting that so of course I didn't bring necessary tools.
This was just a surprise to me and so I started working in it. I honestly never work on this kind of things before so it was a fun experience!
I took the valve cover and left because I was blacking out.
Going tomorrow to get the rest of everything :D
Yay got the head, intake manifold, ecu, coil pack, fuel rail, and knock sensor.
Last thing is the engine harness. Anyone want to jump in and let me know if I need it? It's almost out just need to remove some clips and the figure what this wire is (Last Picture)
What year is your galant?
2014 Lancer Evo GSR
1996 Galant S 5 Speed Turbo
I know what year a GS is. I owned the one MKO now owns and AWD swapped. Are you pulling the harness and ECU for him or for yourself?
2014 Lancer Evo GSR
Really depends on the direction. It would be plug and play for you.
2014 Lancer Evo GSR
Forgot I had this manifold ;)
you're gonna need the crank position sensor since all that is in the distributor. I see you got the cam position sensor, just pray you didnt break it. I'd also get the timing belt covers. The middle timing belt cover for 4g64 DOHC is not available, but 2g one fits alright and thats in case you broke them or were broken from before
nah, this is the cam sensor.
this is the crank pos sensor
yeap u could
