So.... you need help?
Or..... what's the deal?
I hate how the power antenna sticks out on my car..
So i completely remove the antenna that's mounted on the left side near the trunk
i was gonna go with a shark fin aerial antenna with vortex generators...but decided just to get VG and use a hidden antenna and place it in the trunk where the power antenna was bolted..
Power Antenna.
Removed.
Bodywork done to fill the hole.
Sorry posted the image kinda late, as you can see i got it done.. Below is a link for the hidden antenna i plan on using..
<a href="http://www.ebay.com/itm/Hidden-Antenna-Radio-Stereo-AM-FM-Stealth-Universal-Vehicle-Car-Truck-Motorcycle-/221567305135"> Hidden Antenna Radio Stereo AM FM</a>
the hole needs to be welded shut and then bondoed over.
The way, you have done it, will cause the bondo to crack over time. Ask me how i know
you have a point..it was on my mind that it may crack, there's a thick metal strip fitted on the hole and then it was bondoed...but im gonna get it weld and see how that goes..
