Made myself a custom
Cop kit.
[IMG]http://tapatalk.imageshack.com/v2/15/02/01/8e2b2134ba09b3c60e853776004cfbbe.jpg[/IMG
New rear toe arms, tie
Rod ends and swaybar bushes fitted. New tyres and wheel alignment and now feeling tight as a nuns........ Hmm u get the idea. Lol
Cop kit.
Now That One Bad A$$ Bad Boy
Some
Updates.
Cusco rear sway bar.
Nice! what's the thickness of it?
24mm. Heaps better than stock.
Instead of under steer it shuffles the rear end. Nice for
Powering out of corners. And also helps turn in
^Noice! You should get some launch videos
I will do as soon as it dries up a bit. All it does is limiter bash all the way to 3rd. Lol
New rotors. And 1000 cc injectors installed.
Rear rotors in.
Radiator cracked on the weekend. Lucky I had an old golpher alloy rad waiting to go in.
Well another update. Tuned for e85 ethanol yesterday. Results were looking promising untill we found weakness in the head bolts. Started to push water from the radiator out the overflow.
