NEWBIE
Installing new lifters.
My 03 Galant, 2.4 has noisy lifters; so I'm thinking of putting some new ones in. I'd just like to know if anyone else has installed new ones and whether or not this fixed their noisy lifters. Also; what did you use to hold the lifters in place so they won't fall of the rocker arm's while putting the shaft back in. One more question, when a lifter is bad, is it easily compressed? Or is it the other way around?
Here are two threads talking about lifter tick. There are lots of suggestions like using ATF, seafoam, changing the oil to a different brand, etc. Also suggestions on lifters and where to buy them -
https://www.thegalantcenter.org/show...m-side-effects
https://www.thegalantcenter.org/show...e-lifter-noise
https://www.thegalantcenter.org/show...lash-adjusters
http://www.vfaq.com/mods/lifters.html
