OK so the long awaited rear wide body kit from Varis has arrived finally!
So I finally removed the rear fender flare to get a real idea of the amount of space I need to clear.
As you can see below there are some major differences in body shape even though the evo 6 has the same rear Door panel. I have to cut some of the rear flare down, and I have to make a fill in patch about 3 inches wide from the door piece to the rear panel piece.
I have everything mark for locations but before I start drilling holes and cutting I need to come up with a way to fasten it to the stock body without showing and able to remove easy if needed.
I am also thinking about using the rubber trim peice from the jdm flares to make a nice smooth transition from the Widebody to the stock panel, but I would like to see what others have used instead of oem.
This is a general layout of the idea in my head. Right now I might be redoing the front fender because idk if it flows right with the rear portion.
That's it for now :)
