Can someone post link for part 1?
Sent from my One X using Tapatalk 2
yup...Dead links for me also.
I have been getting reports and request saying the full down load doesn't work... I think it is probably because there .rar files so I uploaded zip files... see if that works... You can find the zip file links here: Click Here. I will also only update that one thread so I don't have to keep jumping forums to update... Hope that helps everyone who can't seem to download...
you don't happen to have this in one rar do you? please?
2007 Galant GTS? 2.4L
Awesome info... Just downloaded the .zip files
T.I. 04BUILD YOUR OWN
Looks like the free service I was using has alot of problems so I will no longer host the files there but on the Galant Forums.net server. You can find the download to one .zip file here: http://www.galantforums.net/download...ervice-manuals
Because of the size of these files I may have to take them down every now and again to save on bandwidth. If that happens I will post on this thread: http://www.galantforums.net/forums/8...ce-manual-7226
When I will take it down and when it will be back up. Hope this helps everyone from having to so many problems with it...
This was incredibly helpful!
Links down :(
Does anyone still have this manual?
Okay everyone... get this while you can!
I am not going to host this on my servers any more because when I do they just get hijacked by spammers and they suck up a ton of bandwidth. So I am going to upload this to a site I found one last time and someone else will have to start hosting these files. The site I have chosen is called File Dropper.com and it looks like if the files do not get downloaded at least once a month they remove the files. In any case here is the link to the 8G service manual...
http://www.filedropper.com/8g-galant
What is that? It still does not work
File Details:
Filename: 8G-Galant.zip
Size: 0 KB, Type: zip
Sponsor: Hiveocity Dedicated Server
hit counter
Links on file dropper seem dead. Would someone please upload them again?
Thanks,
Nevermind. I think I found what I needed here:
http://mmc-manuals.ru/Old_Mitsubishi...subishi_Galant
https://goo.gl/photos/ohEiVXZuRq7TyPse8 There are the resistance values for Cruise control switch testing. Do disconnect the negative battery terminal and allow the capacitors to dissipate, and do not reconnect the battery until the airbag is reinstalled or you will get a SRS light on the dash that will require a trip to the dealer to reset
Would be nice to have a pdf of the galant service manual for the 8G .
