NEWBIE
AC drain hose plugged
Since I can't seem to find any threads... where is the drain hose? I found a hose that sticks out of the firewall, but it's covered up by some metal lines. I think they might be brake lines... any help? Pictures would be great too :)
it's located at the lower center of the firewall. Unless you have super skinny arms, you can only access it by lifting the car and go underneath.
Member
Whats the issue? are you getting the wet floor board thing, like most of us here?
