The simple solution is to continue using a cable-driven throttle body. Depending on choice of manifold and throttle body, you will either need to make an adapter so that the throttle body bore lines up with that of the intake manifold, or cut and weld the proper flange onto the manifold that matches your throttle body of choice.
