what are the codes setting off the lite? if you dont know that, you need to start at square 1. and, having a bozo redo the caps is a very common error with the vr4's. it needs to be done by a competent person. you can TRY jeff([email protected]), but dont badger him if he dont want to do it. and dont even send it out unless you KNOW why the ce lite is on. a simple buzzer from radio shack can tell you what codes have been thrown.
http://www.vfaq.com/FAQlocator-index.html
under electrical, look for ecu codes and follow the instructions.
