They are the same as the stock US which IIRC is 9003's and 9004's . You would have to re-wire like I had to re-wire for my JDM's with the city lights.
Damn - I like those 93's so much more than my JDM's . :shock:
What kind of bulbs can you go with 93's? Are they H4's?
Tell me, is this re-wireing a big project? Is there any tutorial any where... vfaq - maybe?Originally Posted by PRE-EVO
It's not too hard more or less you will need to add some connectors for the bulbs to plug into (on mine I had to swap connectors in the opposite way you will I went from US to JDM) . It would also be a good time to upgrade the wiring on the lighting which will make them even brighter. Here is a good basic link to explain how to re-wire your headlights:
http://lighting.mbz.org/tech/relays/relays.html
Thanx for that info Pre-Evo
The Xenon lights i have seen in stores, dont need re-wiring or anything as they are standard
Some tips for the headlights.
The JDM lights have a tendency to get dity in time (don't know about the USDM). The lenses and reflectors go black. You can clean it by:
1. removing the whole assembly and the wirings installed
2. mix laundry detergent soap with water
3. place the mixture inside the assembly and shake it like crazy
4. repaeat step 3 until the lenses are completely clean
5. rinse it off very well
6. dry it up using a hair/blow drier aimed at the inside.
** don't use tap water if it has minerals/sediments. it could leave some nasty water marks **
It would look like new. did it on my galant, and it gives a better light now.
