The cheapest place I've seen the Levoc Hybrid knobs by Napolex is on www.optauto.com. Heres the tutorial that was made for it by DangerDAn.
http://www.dangerdanj.com/shift_install.html
Is there a way to replace the shifter on an auto for something more attractive like a trigger style or somethign like that.... a guy told me today hey have you thought about changing your shift knob and I was like no I didn't know you could do that so I am aksing everyone here. I've done a search and can't finf anythign on it so here goes.... opinions are greatly accepted.
Damn they got some pretty tights ones on that site. I like the one that Danger Dan has on his G.
Yeah I got the sparco hood pins and the same shift knob hopefully i wont mess up the installation, and without that tutorial i would be screwed cause the installation instructions that come with the shiftknob are all in chinese.
i just put a levoc shifter in my g. installlation was easy. now i am getting the ractive ebrake as we speak
hey did you have to do any cutting of the stock shift knob? and is your shift knob with the overdrive or not?
yah i bought the one with overdrive button but it doesnt do anything unless you hook it up so i just left the two wires hangling and yes i did hafta cut some. if you notice when you get the knob off the white peiece looks like a scalpel thing. just clip the top part off and it slides on. but becareful. you hafta make sure to cut enough. even tough it gets on and you can shift no prob, it still might not be on correctly and you will find that out when you cant take the keys out of the ignition.
cut here........./....|
http://www.optauto.com/webstore/product_li...=3200&last=3200
would any of these fit my ride?
Diego
I ordered the levoc carbon fiber knob w/od yesterday. I;m finishing up my trunk with streetglow lights so I am going to have them wire up the od button to run the neons. Will post pics once everything is set.
Ahh you bought one already
Anyways, this is the one I have in my G...it looks pretty damn good
http://www.autofreak.net/cgi-bin/elixir/vi...to_Goods&id=518
Check that link out, they also got a ton of other goodies at this site:
www.autofreak.net
How does the wire come down on the levoc shifter with od like DangerDan? I want to be able to hook up neons in the trunk but I don't want it to be a chore. Anybody with experience that knows that can help thad's be appreciative. I'm trying to plan before I get the hardware(hopefully Thursday) so I can get it done and have my trunk mod complete by the weekend.
the wire comes out from the bottom of the knob. to wire it to something cleanly, you'd have to remove the trim ring off the shifter bezel. then remove the cover for the shifter. the part with teh P R N D etc etc. and then run the wires for the neons. a lil tip. you can't take off the cover for the shifter with the knob on there, so do that while you arein teh process of installing the nknob.Originally Posted by Wolfman83
All that can be put back on though right? because if they can't forget it I want everything to look clean when its on there.
if you take it out carefulyl without breaking anything you can put it back on. just make sure the wires don't mess with the shifting mechanism.Originally Posted by Wolfman83
Well I got my shift knob and used Danger Dan's tutorial I had it hooked up in a few minutes....... although I don't have the big screws that go into the back of the shifter. I can't seem to find the ones that came out of the stock one they disappeared.... anybody have clues? The silver screw that comes with the kit doesn't fit for some reason......probably because its not got a tip or maybe its too big I'm not sure anyway suggestions would be helpful. As far as hooking up streetglows......well they only had one blue in the 15" so that kinda sucks I need two... maybe I can find another one in town or in Fresno but I need it done tomorrow and can't go running everywhere looking for one.....oh well we'll see hopefully everything will be done in time for Import Revolution on Saturday in San Mateo... if not I have everything else hooked up so It still looks sick.
you can get the screws at the hardware store. i got some replacement screws there. they are really short. i forgot the thread size but they do sell it. i think i still have the baggie in the trunk, but no promises.
its a metric sized screw if that helps...
$104???????? www.jcw.com has it for 80$$$$$ mad cheapppppppppppppppppppppppppppppppppppppppppppppp ppppppppppppppppppppppppppp
ok ok the screws. its a 4mm-7 screw. the length is short. i got 10mm bolts and they are way too long. maybe more like a 5mm or something
