#1 |
Trade Rating: (7)
beam514's 99 Galant: 3.5L Swap
Modifications:
[x] = installed [p] = in the process of being installed [$] = purchased, but collecting dust [ ] = future part Engine: total spent: $1000+ (replaced timing belt, water pump, pulleys, etc.) [x] 3.5L 6G74 Swap <$450 + 80 gas/tax = $530> [x] Diamante Intake Manifold and Throttle Body [x] 6G74 injectors [x] Modified stock intake piping w/ K&N <$80> [x] Braille 11.5 lb Battery <$155> [x] Prothane Motor Mounts <$80> Transmission: total spent $1300 + [x] F5M51 5-speed manual transmission <$600> [x] OEM Resurfaced Flywheel <$86> [x] shifter assembly [x] used shifter cables [x] Aluminum shift knob <$23> [x] shift boot (doesn't fit too well) [x] SPEC stage 1 clutch kit <$327> [x] slave cylinder (also have an extra one) [x] master cylinder <$27> [x] transmission mount [x] hydraulic lines <$90> [x] Manual Starter Locator Plate [x] intermediate shaft <$150> [x] clutch pedal [x] Pennzoil Synchromesh Exhaust: total spent $187 [x] MagnaFlow Universal Muffler - 14827 Street Series <$127 + $60 labor = $187> Handling/Suspension: total spent $825 + [x] Progress lowering springs <$70> (great deal from BGR) [x] KYB-AGX shocks/struts <$400> [x] RMR 24mm Rear Stabilizer Bar <$185> [x] Do-it-Center rear camber "kit" (grade 10.9 bolts) <$20> [$] COMPLX rear tie bar <$150> [$] COMPLX front adjustable end links [$] OEM 3G Eclipse GT Strut Tower Bar (doesn't fit with my 6G74 TB. will fit after 5 speed swap) <$50> [x] Power Steering delete Wheels and Tires: total spent ~$1000 [x] Candy Purple Enkei RPF1's, 17x8 +45 [x] OEM Eclipse GT wheels painted bronze <$225 + $30 in paint = $255> old [x] Yokohama Avid W4S - 215/50/R17 <$725> Exterior [x] SEIBON EVO style Carbon Fiber hood <$150> [x] 98-01 Integra Spoon Lip <$60> [x] DDM Tuning Slim Ballast 4500K H4 hi/low kit <$50> [$] Erebuni 384 (I think) style sideskirts <$60> [ ] Cyber Legnum rear lip Audio: total spent $200 [x] Kenwood Headunit and Infinity Reference speakers <$200> All work, besides welding, has been done by me, with the help of my dad and some friends as an extra set of hands __________________________________________________ _______________________________________ Well I finally feel like posting some pics up of my car. Its basically stock but whatever. Today I was finally able to take out the lower dash (thanks 99galant) and I got some paintin done and I think I'll be up all night finishing :D Well here you go: World's biggest wheel gap ![]() Here's what my interior is like right now: ![]() two completely different screws?? I think they ran out of the same kind when they were puttin in the glove box latch: ![]() and I'll post more pics later! Last edited by beam514; 06-17-2011 at 11:51 PM |
#7 |
Trade Rating: (0)
that's a big first project man. But if you have help, it shouldn't be too desasterous have fun and good luck. Bring on the new pics, i wanna see!
__________________
-Pedro
#8 |
Trade Rating: (7)
well I'm pretty much done:
![]() I know the clear coat looks really cloudy and looks like it sucks, but it's really not that bad in person I still have quite a ways to go on my learning curve of clearcoating though :( ![]() The little cubby thing is back in now too just in case anyone was curious, i used Krylon Fusion gloss black first (the store didn't carry the flat black), then some coats of normal Krylon "ultra-flat" black, then regular-gloss Krylon acrylic clear coat, and no I didn't wet sand the clear coat I might end up removing it all again someday and respraying and reclearing. Next time I'll be able to remove everything faster too. This only took like a day for me to do I just didn't have time to post pics now time to find something else work on 8-) |
#13 |
Trade Rating: (13)
the vents you just pry out, looks like it is foggy. if you use regular acrylic clear on the fusion paint it will either make it crack or not adhere to it hence that glazed look i suggest you redo it and either use no clear at all or make sure to buy the fusion clear
__________________
#14 |
Trade Rating: (7)
really?
what if theres a layer of normal Krylon paint on top of the fusion? Also the glovebox is the thing that looks most glazed cause I tried to use satin clear on it and i messed up.. although i used that on the door armrests and those came out perfect. But with the glove box, radio bezel, and shifter bezel I didn't use Fusion cause though I actually sanded and prepped |
#17 |
Trade Rating: (7)
actually in that pic the wheel gap is kind of exaggerated cause I parked on a slope with that fender facing uphill and its slanting diagonally across the car. I dunno about lowering anytime soon as I don't feel like droppin $500 right now (possibly saving for a 5 speed swap ;-))
| Thread Tools | |
