Thread: 1.8" drop any else have problems with that?
Showing results 1 to 2 of 2
    xSILENTx
    I got new wheels bearings installed 2 months ago and got my springs put on last month and now my drivers side bearing is busted again. Is this from lowering the car? I knew it would make things wear faster but not that soon. I mean its not even dropped 2 inches. If there gonna casue more problems i'm might have to take off the springs.
    I can't see bearings wearing out from lowering the car, especially since the first time they wore out, you didn't even have the car lowered yet. You might want to check that driver side axle out. Maybe the axle is messed up and causing the bearings to go bad. Are you sure it's the bearings that are bad this time? Perhaps it's a CV joint or something?
