it'll bolt up but the downpipe wont fit
will these fit, they look like they have the same bolt pattern, i'm pretty sure that the block bolt patterns are the same..... what do you think?
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2443649661
i should be ablke to get a muffler shop to make one, wonder how difficult it would be, or if it would even be worth it to use them....
i have this feeling that it won't fit. the NT versions of the eclipse for the second gen came with 2 motors. the hard tops with hte chrysler 420a and the spyders with the 4g64. if it was for the syper, they probably would say for spyder. but yea b4 purchasing i'd confirm with the seller that it is definitely for the 4g64 and not the 420a.
and for the record, there wasn't a NT version of the 4g63 for the second gen eclipses. only the first gen. the spyders got the 4g64 because they needed a lil bit more power to compensate for the added weight of the spyder
A few 2g NA talons had 4g63s 8)
The part with the flex section IS the down pipe. no need to have a mufler shop make anything...If its for a 4g63 or 64 (wich I doubt) it will fit, however you will have to get a shop to cut that mounting flange off, that wont fit on our engine wich is why im leaning towards it being for a 420a.
Also, the flange after the flex section looks like its a triangle with 3 bolt holes and if I remember correctly the galants piping all have 2 bolt flanges except for the one that conects to the muffler. So that may be another issue.
Rob
rIp 97 Galant
starting over.
90 Talon
so no way at all this will fit?
You'll have to get a muffler shop to custom make you a down pipe.Originally Posted by Qnzfinestplaya
those and RPW
http://www.visionimports.com/headers03.html#anchor_99
so will these fit?????????Originally Posted by krazienluv10
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2446500919
non-turbo 2.0L 2gs were 420a, so those would not fit from my knowledge. Has to be from a 4g63 engine or 2g 4g64 2.4L
RPW. Racing Peformance Works. An austrailian that specialises in Mitsubishi, Proton and Hyundai vehicle enhancements for street, strip, rally and drag car racing.
http://www.rpw.com.au/
www.visionimports.com sells RPW headers for the galant...
