Thread: 450 injectors with sds
Showing results 1 to 4 of 4
    bam462
    ok i emailed ross and have not heard back from him yet on if sds comes with injectors or not, maybe vegasmatt or someone who has there sds can tell me. and if i need to get them from someone else then is 50 dollars for a used set off a 2 g eclipse with 85k on then a good deal.
    Mitsuturbo
    yeah, that's a pretty good deal
    they go for more than that on ebay consistently
    Mitsuturbo
    8ggalant
    ok ...yes the sds comes with 1 addition injector...as for runnin dsm 450cc's yer gonna have to do sum wiring witch makes the simple/clean install of the sds look cluttered/ghetto (imo) so i would say just bite the bullet and get aftemarket injectors....plus the sds is tuned to therr fuel system so they'd probly have to tweak the setup again...but thats juss my lil bit'o knowledge....im sure ross will have it explained more thoroughly
