Thread: Should I consider Cam Sprockets for my 99 Galant?
Showing results 1 to 14 of 14
    I will be hitting 60k miles in about 3 months and I was thinking about changing my Timing Belts.
    It also dawned on me that if the engine needs to be lifted, and the cam sprockets are exposed, why not just change them out, right?
    Anyway, I just wanted to know if this is a good idea or should I just save the money for some nice rims.
    BTW the car has no mods as of yet.
    [b]<span style='color:#800000'>1999 Galant ES Barcelona Red Pearl w/leather</span>
    <span style='color:#800000'>Brembo Rotors - dimpled and slotted rotors with
    Axxis pads</span>
    <span style='color:#800000'>GDI Imports Reverse Indiglow EL Gauges</span>
    <span style='color:#800000'>Rosin CD/DVD Head Unit with 7" Motorized LCD</span>
    <span style='color:#800000'>2 SoundStream Amps for a total of 1800 watts of power</span>
    <span style='color:#800000'>6 Kicker component speakers, and 1-12" Kicker Solo Baric L5</span>
    <span style='color:#800000'>1Ghz PIII AutoPC to manage my MP3 playback</span>
    <span style='color:#800000'>Still thinking on what's next</span>
    You can check out the pics at
    http://photos.yahoo.com/nene1120
    Last update :2/2003
    Baltimore, MD
    2,848
    You're not going to see much of a performance gain by changing your cam gear unless you replace the cam as well.
    Chip
    (Paint Code: Porsche LC9Z)
    My car only has one cam Shaft right?
    Axxis pads</span>
    Last update :2/2003
    Baltimore, MD
    2,848
    Yep. The 4g64 and the 6g72 are SOHC power plants
    Chip
    Senior TGC Member
    2,175
    I think the V6 has 2 cams right?
    <div class='quotetop'>QUOTE(Rallifan)</div><div class='quotemain'>I think the V6 has 2 cams right?</div>
    nope. just one. SOHC stands for Single Over Head Cam
    with an aftermarket cam gear besides being pretty, is adjustable. and to see any gains if any, you will have to put your car on a dyno and get the cam gear tuned to your car. you can leave it @ the oem setting but then you won't see any of that fractional power gain
    2 cams one per head SOHC mean one cam per head. DOHC means two cams per head one intake one exhaust.
    Wes
    Another fine post brought to you By:
    The Man™
    Search the boards first please!
    Senior TGC Member
    2,175
    I'm so confused now...Vision tells me that I'd need to buy 2 camshafts for my V6 and then I read this...I'm turning to mush.
    V6 requires two camshafts period. No maybes Look in the service manuals.
    Wes
    The Man™
    Senior TGC Member
    2,175
    Ahhhhh ok ok lemme see if I got this...the reason why the V6 needs 2 camshafts is because of its V shape design, thus 2 heads, and being SOHC it therefore requires 2 camshafts, whereas a V6 DOHC would need 4 because it has 2 cams per head...
    Thats it! One camshaft per head in a Single overhead cam setup. This camshaft drives the intake and exhaust valves. In a DOHC setup you have two camshafts per head one drives intake one drives exhaust and can be tuned seprately thats why people like DOHC setups more. non overhead cam engines aka inblock cams drive all valves for all heads with a pushrod setup into the block.
    Wes
    The Man™
    Gilhuly
    OK, now that that's settled - does it make any sense to have Cams, gears replaced on the V6 at the timing belt replacement? Are there any efficiencies from a labor standpoint?
    toc8g
    But remember the I-4 only really has one cam shaft,..not two like the V6.
    Senior TGC Member
    2,175
    I would say yes, do it at that time since you're taking things apart anyway...
