Guages required for SDS
In everyones personal experience/opinion, whats the most essential guages to purchase if I go with the SDS system? Thanks
I have boost, trans temp, air fuel ratio and EGT
I also have but not necessary, water temp, oil pressure, volts
Love,
Matt
Currently I have EGT, Air/Fuel, and Boost... I would also go with an Oil Pressure gauge.
Trans temp, oil temp and oil pressure IMO and Boost....gotta have the boost
Where did you guys mount all these? I was under the assumption that I would probably need 3 guages at the most, and would mount them in the open space below our AC guages, where did you guys mount the rest of them?
Ill take a pic of em for you but this is what I did.
Moved the radio to the bottom din, and put 3 gauges in a custom carbon fiber housing where the radio used to be. Then i took a A pillar gauge pod from a CRX and molded it to fit the pillar. I also have a custom bezel that holds two gauges in the corner of the instrument panel. Where the gas and rpm is. Its pretty slick. Ill try and get pics up tomorrow of it.
Love,
Matt
<div class='quotetop'>QUOTE(VegasMatt)</div><div class='quotemain'>Ill take a pic of em for you but this is what I did.
Moved the radio to the bottom din, and put 3 gauges in a custom carbon fiber housing where the radio used to be. Â*Then i took a A pillar gauge pod from a CRX and molded it to fit the pillar. Â*I also have a custom bezel that holds two gauges in the corner of the instrument panel. Â*Where the gas and rpm is. Â*Its pretty slick. Â*Ill try and get pics up tomorrow of it.</div>
That'd be awesome! Thanks!
Love,
Matt
