<div class='quotetop'>QUOTE(extremsprt86)</div><div class='quotemain'>what i really need is a jack point on the front of the car so that i can get jackstands on both sides of the car at once. Â*i need this in order to prevent extreme angles n such that occur when i jack from one side at a time. Â* and with the car being lower it would make a lot less work getting the jack under the front sumwhere. Â*so is there a safe spot to lift from in the front. Â*i have '02 es i4 if that makes a diffrence.</div> Yea, you have one. It's right in the center of the lower motor support brace. It's a round spot with a jack mate in it. Theres one in the rear too. You just need a floor jack that goes high enough to lift from that point.
