here's a picture
for the ones that say you need longer wheels studs, you get the one on the right. its just a spacer. you need longer wheels studs to comensate for the thickness of the spacer.
for the oncs that are included, its the one on the left. you slip the spacer on thru the holes and there are special nuts that bolt the spacer to the hub, kinda like your wheel would. then you put the wheel on them studs that come with the spacer.
