Anyone?
As some of you might know, I'm rebuilding the front of my car because of an accident I had in November.
Now I'm up to the part where it's time to put everything back together.
I connected my horn and my hood lock today and both work fine. But now I need to tie the cables to the chassis as they were. But I forgot how they went.... So can someone explain that to me, or make a small photoshop picture that shows me where I should tie de cables to the chassis.
Oh I also would like to now this for the big black cable that contains the cables for the headlights.
Check the other topic for a tiny update on the rebuilding process.
Thanks,
Chris
1990 Mitsubishi Galant 2.0 GLSi Hatchback *SOLD*
2004 Renault Clio 1.5 dCi
Anyone?
Well ok, then I will try something myself then.
Still need help? I have the manuals in PDF if you need that, just tell me what subject you need and i can extract that section
<div class='quotetop'>QUOTE(marktheblake)</div><div class='quotemain'>Still need help? Â*I have the manuals in PDF if you need that, just tell me what subject you need and i can extract that section</div>Like I said in my first post. I would like to know how the headlight cables go. They are usually connected with some sort of tie rip to the chassis. I would like to now how the cable goes along the front chassis.
i can take some pics for you, but not now cos its Dark....
send me a PM, within the next 12 hours and that way i will get it in the afternoon , and i will do it.
