Thread: ABS Disable
Showing results 1 to 4 of 4
    Bumpy
    ABS Disable
    Hey all my first post on this forum
    I have a '88 JDM VR4 (Full Jap import)
    This make it hard to read the fuse pannel
    Could someone please tell me which fuse is for the ABS Brakes ? I really need to remove this, as my VR4 will be a part time rally car (Dirt + ABS = VERY BAD :twisted:
    Thanks in Advance ppls
    Bumpy
    Rasko Da Gama
    Disabling ABS is not that simple... You can't just put out the fuse. Go to www.galantvr4.org and ask those guys - I saw a tutorial for removing ABS in GVR-4...
    Good luck and welcome to TGC
    Bumpy
    Thanks
    Thanks Dude,
    But i would like to be able to turn it off and on at will, if possible (might get in trouble at rego time if its not there).
    Thanks
    Bumpy
    Rasko Da Gama
    OK, you can go to http://www.vfaq.com/index-main.html and find "From ABS to non ABS" tutorial under "Brakes section".
    But I also saw a tutorial for making a switch... than you can either enable or disable ABS...
    Like I said... go to www.galantvr4.org and search the forum. I know it was done before.
