Thread: 15,000 miles..
Showing results 1 to 3 of 3
    kidrocking79
    15,000 miles..
    Took car to dealer for oil change.. now they want me to do the 15,000 mile service.. It's 300 bucks.. no way.. It's a freaking tune up.. so What plugs do u guys recommend, and should I even bother changing wires yet??? also.. they say that they will do an EFI system service.. anyone know wtf that is?
    plugs, wires?? they said you had to change that? your v6 should have the platinum plugs. that last to 60k. cuz the plugs in the rear bank of cylinders is kinda difficult to get to.
    Gilhuly
    Agreed. I can't think of a single thing that needs to be done at 15K other than rotating tires and changing over to synthetic oil! I changed my OEM plugs at like 63k and they probably had 20k left on them. Buy yourself a K&N filter, do the flip box intake, change to synthetic, rotate those tires, put real hose clamps on the main radiator hose connections and you are totally set.
