Thread: 1995 Mitsu Galant (94 to early 95) - Recalls I found.
Showing results 1 to 2 of 2
    Member
    08-18-2002
    Pocono Mts. PA
    254
    List of recalls for this car. Hope it helps.
    Recall Alerts
    for 1995 MITSUBISHI GALANT 4 Cylinders G 2.4L MFI
    Title Number Date
    Recall 98V020000: Sunroof Control Defect NHTSA98V020000 01/30/98
    Recall 98V212000: False ABS Warning Light Problem NHTSA98V212000 09/02/98
    Recall - Stop Light Malfunction SR-98-006 11/01/98
    Recall 99V066001: Damaged Lower Ball Joint Boots NHTSA99V066001 04/05/99
    Recall 99V066002: Damaged Lower Ball Joint Boots NHTSA99V066002 04/05/99
    Recall 00V237000: Possible Fuel Tank Leaks NHTSA00V237000 08/25/00
    Recall - Fuel Tank Leak SR-00-006 09/01/00
    Recall 00V421001: Lower Ball Joint Separation NHTSA00V421001 12/15/00
    Recall - Lower Ball Joint Replacement SR-01-007 03/01/01
    12-17-2002
    Sherman Oaks, California
    4,304
    fuel tank leaks, great, my mileage is shitty enough as it is
    http://socallifestyle.com/
    1994 Galant GS 5spd
