18"rims
Anyone have 18's on an I4 and lowered with eibachs that ran into any problems. I'd like to kno before i buy them. thankx
several have that setup i believe. just gotta watch the offset on your wheels. 40+ is cutting it close and you very well may rub. i think oem offset is 45+ and yes it does make a difference
Actually the stock rim offset is +46mm. Find a rim that is between +46mm and +40mm and one that is no wider than 8" (you might get away with 8.5" depending on the offset you get) and you will be fine. Probably the best fit would be a rim with a +45mm offset that is 7.5" wide. Also, get some tires that are 225/40/18, that's the perfect tire size for 18's on an 8G Galant.
