Thread: tein tech spring
Showing results 1 to 2 of 2
    tein tech spring
    im planning to buy the tein tech springs they have a 1.7 front 1.5 rear they only ything is its for the eclipse 00-03
    1) will this fit my 99 galant ?
    2) will i need a camber kit i have 17''
    3)if i get this kit/brand will i still have the gap in the front wheels ?
    does anyone recommend any other brand/set of springs that can fulfill my needs which is between 1.4-1.8 fills gap in front wheels thank you
    If you want to completely get rid of the gap I'd suggest ground control coilovers and KYB AGX's. Progress springs give a nice drop, nearly 2 inches all around. I personally have Teins and they don't come close to getting rid of the entire front wheel gap, it does close the 4X4 look though and its stance is aggresive just not as much as others. As far as camber kits go ech car is different. Personally I needed rears but no fronts. Brand wise I'd recommend ingalls.
    -Nathan
    member of Team DNA
    www.dnaracing.net
