Thread: 7gers + 17s = Post here!
Page 2 of 2 FirstFirst 12
Showing results 21 to 27 of 27
    12-17-2002
    Sherman Oaks, California
    4,304
    <div class='quotetop'>QUOTE(2True)</div><div class='quotemain'>I think peano was reffering to that setup as mounted on a 7g. Â*
    A 235 will def fit a 7.5" wheel, but application wise it would never work unless you had some serious fender work done.</div>
    i'm not too sure on that, you get 235s to go onto 8 inch wide wheels, just ask the goons at your local tire place
    http://socallifestyle.com/
    1994 Galant GS 5spd
    how about a 17x7 wheels with an offset of +42mm, riding on a 215 40 tires without a drop on the car? any suggestions on w/c tires would best fit the wheels? :?:
    steveo1
    i'm a 205/40/17 on the pro kit about a 1" gap or so. the falken ziex512's grip mad!
    Sharky1116
    whats the lug nut size on a 7G? is it a 4x100 or 4x114.3?
    not sure what the 4x thing means.... :oops:
    iam thinking about getting these....
    http://www.speedandstyle.com/index_main.htm
    The REV BOOST style 17x7 with 215/40/17 tires...
    02-20-2003
    If you have to ask, then you don't need to know.
    727
    Quote Originally Posted by Sharky1116
    um, it means "times" 4. as in you get 4 of them. 4X114.3 means you get 4 lugs that are 114.3
    ...U N D E A D...
    Sharky1116
    so the 114.3 is the lug size on 7g's?
    12-17-2002
    4,304
    <div class='quotetop'>QUOTE(Sharky1116)</div><div class='quotemain'>so the 114.3 is the lug size on 7g's?</div>
    yes, that is the lug spacing
    1994 Galant GS 5spd
