Thread: Semi-metallic pads good enough for drilled/slotted rotors?
Showing results 1 to 5 of 5
    Mindless
    Or do I need to upgrade to ceramic? The semi-metallic seem to be doing a good job under moderate braking, but under hard braking they suck.
    San Antonio, Tex-Mex
    1,413
    You should be alright for like 10k miles or so...
    <-Check it out Maz
    My 7g
    Mindless
    <div class='quotetop'>QUOTE(2True)</div><div class='quotemain'>You should be alright for like 10k miles or so...</div>
    I'm just getting a lot of fade (I guess that's the right term) under hard braking.
    1,413
    hmmmm... well that is why they are slotted/drilled, to prevent that very thing. Ceramic pads will definately cut down the heat and gas, maybe you should give them a shot, I would be very interested to know how much a difference it makes. I nice set of Axis or Hawk pads could be in my future.. my rotors are only cross-drilled though.
    <-Check it out Maz
    My 7g
    brandon
    I just installed my new rotors and Axxis pads yesterday... didn't notice much of a difference in braking thus far either way, although I haven't done any hard braking and probably will try and avoid that for another 100 miles or so.
