KYB AGX + Eibach = :thumbsup:
I wouldn't worry Kain, that's great setup. If your looking for it to be as soft as the OEM setup then you'll be disappointed. If your ready for a sports suspension then you will not.
I had close to that setup for nearly a year, except I had the GR-2's, and it was great all around. Cornering was tight, and the ride not tooooo stiff. It will be a tad bit bouncy at first I will warn you but it should settle after like a month.
The Eibachs don't really drop the car far enough to worry about strut rod travel. When I drop my Skunks like 3 inches... then it becomes a problem.
