Thread: i need help
Showing results 1 to 2 of 2
    lpfan989
    i need help
    i just got a 1990 mitsubishi galant 2.0 SOHC and i was wondering if it is normal for the car to draw 5 amps with the key off. thanx :?: :?: :?:
    bluedraco
    if the key is completely out of the ignition, then no, it shouldn't be drawing that much...that would flatten your battery reasonably quickly so i suggest you look into it!
