Damn Sabzi where do you get your cash from!
Have you ever thought of swapping the 7g speedo guage with the speedo from a 1g? We all had problems with our tach not working after the 2g swap which I attributed to the fact that its calibrated to work with a distributer single pulse output and needed a tach adapter. I was researching around and found that the early 1g coil packs 89-90 had a tach adapter box on the bottom, I picked up a set removed just the tach adapter and installed it in my setup and boom stock tach worked great.
The speedo does indeed grab the signal right from the speed sensor itself though,( in both galant and eclipse), so you shouldnt really be having any problems.
