Boost gauge for turbo
anybody can tell me how to install it???
yer gonna have to tap a vaccuum source that goes into the intake manifold...u can use the one off the fpr or one of the nipples on the throttle body...cant remeber witch one...other than that u should have the rest of the directions with the gauge
You should probably use the one off the fuel pressure regulator. On most cars, it tends to be the line that provides the most accurate reading of the pressure inside the intake manifold. Buy a t-fitting, and cut the line to the fpr. Hook the T-fitting nips up to the fpr line and the third nipple to your boost gauge line. Run it up inside the cabin, and you're done.
www.egauges.com has a bunch of gauges. I have the VDO gauge in the Audi. You can get tubing kits from them too.
