Thread: INDIGLOS
Showing results 1 to 10 of 10
    San Antonio, Tex-Mex
    1,413
    Re: INDIGLOS
    <div class='quotetop'>QUOTE(ChuBBs)</div><div class='quotemain'>Is there a 7g indiglos tutorial???</div>
    Not a tutorial, but very informative for install.... http://www.tgc-forums.com/phpBB2/viewtopic.php?t=115
    <-Check it out Maz
    My 7g
    Quote Originally Posted by deejunx
    is there a good looking reverse indiglo gauges for 7G?
    here is a set from procarparts.com...can't say if they look good or not...thats ur opinion
    yeah i've seen those on eBay.. those look OK.. but the red line doesn't light up at night/when turned on.. i think that's the only bad thing about it..
    1,413
    Actually the red does show up. The camera just can't catch it in low light. Except for the "donut" they look really good at night
    <-Check it out Maz
    My 7g
    i have those, i blocked out the donut, so u dont see it, all u see is the numbers
    MitsuMan
    what did u use to block out the donut, vinyl? or just like a sticker or sumptin
    take black vynil, make it the same size as the donut, and then use white vynil on top of it, put 2 layers of white, but make the last layer a lil bigger then the whole thing, so when u put it on, all u see is the numbers and the last layer being bigger makes it look perfect
    1,413
    I made the Mitsu symbol using the same technique. :thumbsup:
    <-Check it out Maz
    My 7g
    schick
    If you want to make that permanent (no donut center), you can cut the trace on the back.
    I have the exact same ones (procarparts.com) from Ebay.
    ALSO DO NOT USE SUPERGLUE to put the clear plastic back onto the body.
    Have you ever seen "Beverly Hills Cop II" where Axel puts the match book in the lizards glass box and sets a bit of superglue in there?
    That's exactly what will happen with your clear plastic piece of it's eve remotely warm or humid. The vapors will attach to any body oils that are on the plastic. Pain in the ass to clear up also.
    (you can use super glue, but let it set inside overnight, 72 degrees or less and 50 % humidity or less)
    And yes, the red does show up good, just not in the pics
    nitegsrider
    I have one of the 7 color indiglo gauges from procarparts. They look really awesome i like them a lot. And hell i only paid 25 bucks for them. Off Ebay
    I superglued mine. I just used enough glue to make the needles pass by smoothly. And I did it when it was cool out so no melting or what not
