What tranny's will fit in my '96 G
Need an automatic for my '96 Galant. I am looking for a used tranny possibly out of a wreck. I am looking to do the swap my self so any recomendations are welcome...
Thanks in Advance...
Brian
I assume you desire to stay with an Automatic? Umm, another 7g Galant will work ('95-'98 are all the same, but I've heard there were some slight diffrences with the '94s but it should still work) As will a 2g ('95-'99) turbo Eclipse FWD. An 8G might work, but I'm not 100% on that one. Or, if youd like you could have Level 10 rebuild yours. Just remember, with a used automatic you may be making a lateral move as often they have problems of their own.
ok 8g tranny's wont work cuz they are reverse to the 7g tranny....as for any car that has a 4g engine...4g63, 4g64, 4g92 etc...will all fit ur galant.....levelten upgrades are good, but i will go with a 95-99 2g eclipse TURBO tranny either auto or manual....the swap from auto to manual is easy...check out http://www.vfaq.com/ and look up in the transmission section for the how to on teh manual swap
ONLY the ones from the same year and model. do NOT waste time trying to get others to fit.. too many variables.
