well, all of my window regulators, kind of went out, at the same time. Have you had the car long? if so, when did they go out? chances are, they all decided to die, together.
None of the windows work in the family 7g, and ideas?! the sunroof or the side windows dont work, checked all the fuses and tehre fine :shock:
ZIGONATOR
did you ever remove the master window control? you might have forgotten to plug the wires/harness back in...
the "master window control"
are you talking about the main harness inside the drivers door that connects to the main window controls? for the driver?
because that should have no affect on the sunroof....
check your fuses again. the one in the dash and the one in the engine bay. you might have missed a fuse.
have you done anything to your car recently that might have caused this problem??
did you make sure that the windows are unlocked??
did they all go out at once or like over time? is anything besides those go out?
well yea they all went out at the same time it happened b4 the winter actually just neva got around to fixin it :oops: , ill recheck the fuses again but they all died about a month after i got the new sterio head unit. and nope tahats the only thing that went out
ZIGONATOR
