4g63 engine question...help!!!!!!
OK I have found a guy who is selling his 1995 4g63T (probably for
really cheap, will find out the price today). The problem is a blown
head gasket. He installed the 6-bolt engine on his eclipse to
prevent crank-walk, and push more power.
So here's my question: Is this engine worth getting? How can a 95
engine blow a gasket (high boost???). What are some things that
might happen when head-gasket blows out (bent valves, bad piston
rings, etc.)?
So pretty much give me your opinion on this subject, I don't wanna
spend the money, and later find out that the engine is worthless
(not working at all).
I'll get it and do a valve job etc, i mean the engine aint dead, and it is possible for ANY car to blow the head gasket....when i killed my car, I blew the gasket....and alot of otehr shit, but i'm still running
he had a 4g63t before...now hes running a jdm 4g64
its gets a blown head gasket cuz the engine is too hot so forth maybe the fans newer turned on to cool it down ive blown 2 of them on my previos vehicles cuz of that
Like he say the blown gasket only get the car too hot
maybe cuz the fan din't turn on or run with out coolant
you should buy the engine and take the out send it to
a machine shop and fix for bents or crack from heat
that get a set of gaskets and bilt the engine back then
put it in your car
thats if u buy it sheep cuz fixing it you will spend
at least 3-400 dollars doing it your self ok.
I'm an auto mechanic I work for a hoda dealer
and i have a mitsubishi galant 96 and i don't like honda
and their vtech shit cuz i think we have a lot to give all motor
Mitsubishi have always been better than hoda in raicing ok!
